11 years agosystem console, external memory, multiple masters
Hi guys Im fairly new here. Im working with a cyclone V GX board and have used qsys to add a memory controller in my nios code to control some lpddr memory on the eval board. Im u...
11 years ago --- Quote Start --- Does any of this mean anything to you? --- Quote End --- Nope. If I get errors with Quartus I generally delete all the generated files and re-run a Tcl script to build the design again from scratch. --- Quote Start --- See attached for the signaltap settings --- Quote End --- The attachments are resampled too small. I'm not sure if they are what you uploaded, or whether the web interface resampled them. Try to upload a zip with the images, rather than as .jpg. Although, I should not need to look at the images - you should. What are you looking for? You need to check the baud rate! For example, if I look on an ASCII chart for the hex value 0x55 I see that it is a capital U. If I hit capital U, and then look at SignalTap II, I can measure the bit period in units of the SignalTap II clock, and from that I can confirm the baud. That is what you need to do. --- Quote Start --- again, this sorta code worked ok for jtag_uart. usb_uart cant be that much different --- Quote End --- The two interfaces are nothing alike. The fact that it has UART in the name jtag_uart is completely bogus. Its not an asynchronous UART, its a synchronous JTAG interface that implements a fake UART by polling at a regular basis. Cheers, Dave
