11 years agosystem console, external memory, multiple masters
Hi guys Im fairly new here. Im working with a cyclone V GX board and have used qsys to add a memory controller in my nios code to control some lpddr memory on the eval board. Im u...
11 years ago --- Quote Start --- I see the UART RX pin in signal tap, but not the TX pin in the node finder. Is there a way to manually enter the TX pin? --- Quote End --- Its a top-level pin, so it should show up. Check the filter settings in the setup window where you add the signals to tap. I'm pretty sure there is a pins filter. --- Quote Start --- Also, would i just trigger on the RX pin or a nios variable using the nios plugin? --- Quote End --- Trigger on the falling-edge of the UART signal, i.e., the start bit. Cheers, Dave
