11 years agosystem console, external memory, multiple masters
Hi guys Im fairly new here. Im working with a cyclone V GX board and have used qsys to add a memory controller in my nios code to control some lpddr memory on the eval board. Im u...
11 years agoHi Dave
I see the UART RX pin in signal tap, but not the TX pin in the node finder. Is there a way to manually enter the TX pin? Also, would i just trigger on the RX pin or a nios variable using the nios plugin? thanks
