11 years agosystem console, external memory, multiple masters
Hi guys Im fairly new here. Im working with a cyclone V GX board and have used qsys to add a memory controller in my nios code to control some lpddr memory on the eval board. Im u...
11 years ago --- Quote Start --- Do you have any experience with bytesteam in system console? --- Quote End --- A bytestream is simply an Avalon-ST interface. The NIOS II does not have one of those. If you are using a NIOS II, why not use an interrupt from your device as the trigger? The NIOS II processor interrupt service routine could then decide to read from some location. Cheers, Dave
