11 years agosystem console, external memory, multiple masters
Hi guys Im fairly new here. Im working with a cyclone V GX board and have used qsys to add a memory controller in my nios code to control some lpddr memory on the eval board. Im u...
11 years ago --- Quote Start --- I dont believe im doing anything that shouldnt be possible. just trying to use the system console in a very basic way. but it does seem like hanging issue appears for others as well --- Quote End --- You're right, it should all be possible. However, in my experience, the Altera JTAG software has bugs. Or perhaps that the user-space application interface to the driver and the locking between processes is not quite correct, and you are able to lock it up. I've explained one way that I am pretty sure you can still lock it up, and I suspect that you have found another. Unless you spend a lot of time debugging, you're unlikely to find the source of the problem, or to get Altera to fix it, so you'll have to figure out a work-around :) If you can come up with a small design that can be shown to fail repeatedly on an Altera development board, then file a Service Request with Altera, upload the code, and ask them if they can help. The support people are very receptive to helping and solving problems, but its a waste of their time if you simply complain, its much better to give them an example that demonstrates the issue. --- Quote Start --- I do appreciate your help! youve taught me a few things today !! thanks! --- Quote End --- You're welcome! Cheers, Dave
