11 years agosystem console, external memory, multiple masters
Hi guys Im fairly new here. Im working with a cyclone V GX board and have used qsys to add a memory controller in my nios code to control some lpddr memory on the eval board. Im u...
11 years agoI haven't tried either of the methods you're using, so cannot comment on what I'd expect to see. The only time I use the JTAG master embedded in the DDR controller is to run the DDR memory interface toolkit for sweeping the memory interfacing timing margin.
--- Quote Start --- Ill try adding the jtag to avalon mm master in there and report back --- Quote End --- I know for-sure that this will give you the results that you want. Cheers, Dave
