19 years agoSynthesis side effect between independent components
Hi all, I have a data path consisting of several components with no feedback across them, but when I change a signal in the last component, even with only changing STP signals for debuging, it has...
19 years agoDear Rysc,
Thank you for your kindness. You are all right for your guess. I try to fix timing and constrants for all components. Since only about 58% of the device is utilized I hoped that the fitter has not sever trouble to fit the design. Thank you again. zaamari
