16 years agoSynthesis ramstyle
Hi, I am trying to do the ram code but failed to infer to Mlabs, which instead goes into logic. Can anyone help? I attached the source code. device used:STRATIX V GT Thanks a...
16 years ago --- Quote Start --- Hi, I am trying to do the ram code but failed to infer to Mlabs, which instead goes into logic. Can anyone help? I attached the source code. device used:STRATIX V GT Thanks alot for helping. Best regards Jenny --- Quote End --- Hi, the RAM is implemented in logic, because you are using a asynchronous read. I would follow the advice of FvM and use the megawizard instead inference, because you have a better control over the implementation. However, the following example shows a that the inference in MLAB in principle works. (* ramstyle="MLAB" *) module test(clk1, we, data_out, rdaddr, wraddr, datain); parameter addr_width = 6; parameter data_width = 10; input clk1,we; input [data_width-1:0] datain; input [addr_width-1: 0] wraddr,rdaddr; output [data_width-1:0] data_out; reg [data_width-1:0] q; reg [data_width-1:0] mem [(2**addr_width)-1:0] /* synthesis syn_ramstyle = "MLAB"*/; always @(posedge clk1) begin if (we) mem[wraddr] <= datain; end always @(posedge clk1) begin q <= mem[rdaddr]; end assign data_out = q; endmodule Kind regards GPK
