14 years agoSynthesis of ROM & Synthesis Attributes
Hello, My question is regarding how Quartus handles attributes versus setting options in Quartus itself. For the ROM code shown below, using just the attribute directive, it will not synthesize...
14 years agoI did add the attribute with q as the signal, and this did work. I removed the Quartus settings for "synthesize any ROM size" and after compilation the ROM was placed into embedded memory. This is helpful because when the source VHDL is made with these attributes the downstream configuration options in Quartus don't have to be set, which is what I was aiming for. James
The modified VHDL is shown below:
library IEEE;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity ROM_12x60 is
port(
ADDR : in std_logic_vector(5 downto 0);
CLK : in std_logic;
q : out std_logic_vector(11 downto 0)
end ROM_12x60;
architecture RTL of ROM_12x60 is
attribute romstyle : string;
attribute romstyle of q : signal is "M9K";
signal addr_int : integer range 0 to 2**6;
begin
addr_int <= to_integer(unsigned(addr));
Main: process(clk) begin
if rising_edge(clk) then
case addr_int is
when 0 => q <= "000000000000";
when 1 => q <= "000000100100";
when 2 => q <= "000001000111";
when 3 => q <= "000001101011";
when 4 => q <= "000010001111";
when 5 => q <= "000010110010";
when 6 => q <= "000011010110";
when 7 => q <= "000011111010";
when 8 => q <= "000100011101";
when 9 => q <= "000101000000";
when 10 => q <= "000101100100";
when 11 => q <= "000110000111";
when 12 => q <= "000110101010";
when 13 => q <= "000111001101";
when 14 => q <= "000111101111";
when 15 => q <= "001000010010";
when 16 => q <= "001000110101";
when 17 => q <= "001001010111";
when 18 => q <= "001001111001";
when 19 => q <= "001010011011";
when 20 => q <= "001010111100";
when 21 => q <= "001011011110";
when 22 => q <= "001011111111";
when 23 => q <= "001100100000";
when 24 => q <= "001101000001";
when 25 => q <= "001101100010";
when 26 => q <= "001110000010";
when 27 => q <= "001110100010";
when 28 => q <= "001111000001";
when 29 => q <= "001111100001";
when 30 => q <= "010000000000";
when 31 => q <= "010000011111";
when 32 => q <= "010000111101";
when 33 => q <= "010001011011";
when 34 => q <= "010001111001";
when 35 => q <= "010010010111";
when 36 => q <= "010010110100";
when 37 => q <= "010011010001";
when 38 => q <= "010011101101";
when 39 => q <= "010100001001";
when 40 => q <= "010100100100";
when 41 => q <= "010101000000";
when 42 => q <= "010101011010";
when 43 => q <= "010101110101";
when 44 => q <= "010110001111";
when 45 => q <= "010110101000";
when 46 => q <= "010111000001";
when 47 => q <= "010111011010";
when 48 => q <= "010111110010";
when 49 => q <= "011000001010";
when 50 => q <= "011000100001";
when 51 => q <= "011000111000";
when 52 => q <= "011001001110";
when 53 => q <= "011001100100";
when 54 => q <= "011001111001";
when 55 => q <= "011010001110";
when 56 => q <= "011010100010";
when 57 => q <= "011010110110";
when 58 => q <= "011011001001";
when 59 => q <= "011011011011";
when 60 => q <= "011011101110";
when 61 => q <= "011011111111";
when others => q <= "000000000000";
end case;
end if;
end process Main;
end RTL;
