16 years ago
synchronous process on both edges
Dear All,
is is possible to create a synchronous process reacting on both clock edges? Is it synthesized? Or I have to use PLL to go for twice higher clock frequency and use only rising_edge?
thanks
da.
    no, a process that is sensitive to both edges cannot be synthesized, at least not in a FPGA.
    The general solution would be to use a PLL.
    Of course, in some application cases you can get the job done by using two different processes on the two clock edges. The most relevant case is DDR I/O.
