14 years agoSynchronizing TXCVR & RXCVR
Hello: If the interface between the FPGA fabric and the TX module is a 16-bit bus and the RX is 16 bit bus to the Fabric, is there a good way to synchronize so the RXCVR can detect a speci...
14 years agoI thought I read that after reset the Transmitter sends 3 K28.5 code words automatically.
"Yep. Depending on the ALTGX setup, you can access this signal manually" What signal are you referring? Is there a sample simulation available somewhere? thank you very much
