14 years agoSynchronizing TXCVR & RXCVR
Hello: If the interface between the FPGA fabric and the TX module is a 16-bit bus and the RX is 16 bit bus to the Fabric, is there a good way to synchronize so the RXCVR can detect a speci...
14 years ago --- Quote Start --- if I want to send pattern h1234 to be detected by the Fabric on the receiver end, how do I guarantee that the data at the receiver (rx_dataout [15..0]) will be h1234 and not hxx12 (first word) , h34xx (next word) I guess in general I am asking how do I synchronize to know where my data begins on what byte , etc.. PS: first time using Transceivers --- Quote End --- What device are you using? Cyclone IV GX, Stratix IV GX/GT? Read the Handbook for the transceiver, and look at the transceiver configuration section. The ALTGX component in Basic mode has a receiver pattern detect block which can be used to do what you want. Take a look at the appropriate handbook and try to create an ALTGX component. If you get stuck, ask, and I'll try to help. Cheers, Dave
