15 years agoSV Assertions
I am new to SV Assertions. I wanted to know if I can check a simple clock/3-divider using assertions. All I need to check is if a "Divider_enable" i/p is high, the output clock should be i/p Clock divided by 3. Is it possible to check this using assertions? Thanks in advance SV BabyNo RepliesBe the first to reply
