14 years agoStratixIV GX and SFP
I want use GXB_RX and GXB_TX link to the SFP. The GXB_RX and GXB_TX are LVDS levels. The SFP is LVPECL or CML levels. How to link them? In the StratixIV GT board of Altera, they just li...
14 years ago --- Quote Start --- In my design, the stratix IV GX is used. The stratix IV GT is used in the Altera development board which I can refer. --- Quote End --- Ok, thanks for the clarification. --- Quote Start --- The transciever power supply is 1.5V in my design. Based on your advice, the AC couple mide will be used. --- Quote End --- What is "my design"? The Stratix IV GX design, or the Stratix IV GT kit? In my constraints file for the GX kit I have:
# The GXB voltages can be selected by DIP switches on the boards, eg.
# VCCH = 1.4V (default) or 1.5V (reserved)
# VCCA = 2.5V or 3.0V (default)
# Quartus Assignments->Device, Operating Settings and Conditions,
# Voltage shows the default settings are 1.4V and 2.5V.
# Explicitly assign them per the DIP switch defaults.
set_global_assignment -name VCCH_GXBL_USER_VOLTAGE 1.4V
set_global_assignment -name VCCH_GXBR_USER_VOLTAGE 1.4V
set_global_assignment -name VCCA_L_USER_VOLTAGE 3.0V
set_global_assignment -name VCCA_R_USER_VOLTAGE 3.0V
And if I look at the Altera Stratix IV GT SI kit schematic, I see that VCCH = 1.4. So why do you think it is 1.5V? Cheers, Dave
