14 years agoStratixIV GX and SFP
I want use GXB_RX and GXB_TX link to the SFP. The GXB_RX and GXB_TX are LVDS levels. The SFP is LVPECL or CML levels. How to link them? In the StratixIV GT board of Altera, they just li...
14 years ago --- Quote Start --- I want use GXB_RX and GXB_TX link to the SFP. --- Quote End --- What do you mean by "the SFP"? Do you have an SFP cable, an SFP+ cable, a development kit? Since you mention Stratix IV GT, I assume you are actually interested in SFP+. --- Quote Start --- The GXB_RX and GXB_TX are LVDS levels. The SFP is LVPECL or CML levels. How to link them? --- Quote End --- It depends on what the connection requirements are. If you are using the connector as a standard 10GbE connection, then AC couple the TX->RX paths in either direction, and check either end is terminated correctly. --- Quote Start --- In the StratixIV GT board of Altera, they just link directly. Is it right? --- Quote End --- Which board? The Stratix IV GT Signal Integrity kit? Look at the schematic, it will show you. Most likely the connection is transceiver to SMA connector without anything in the signal path. You may want to include a DC block between TX->RX paths to block the possibly incompatible common-mode voltages. That would of course require the signals to have no DC bias. But if you are transmitting 10GbE, the signals are 64/66B encoded, so you should be fine. Cheers, Dave
