14 years agoStratix5 PLL
I had generated Stratix5 PLL (s5_pll) using Megawizard Plugin and the created pll instance is pll_test_0002 with a top level wrapper arouND IT. tHE GENERATED FILE IS SHOWN BELOW;module pll_test (
input wire refclk, // refclk.clk
input wire rst, // reset.reset
output wire locked, // locked.export
output wire outclk_0, // outclk0.clk
output wire outclk_1 // outclk1.clk
pll_test_0002 pll_test_inst (
.refclk (refclk), // refclk.clk
.rst (rst), // reset.reset
.locked (locked), // locked.export
.outclk_0 (outclk_0), // outclk0.clk
.outclk_1 (outclk_1) // outclk1.clk
endmodule Now i have a top level instance top.v with instance pll_test along with some sub-modules. While synthesis in Quartus, toll gives below error; -------------------------------------------------------------- Error (12006): Node instance "s5_pll_inst" instantiates undefined entity "s5_pll_0002" Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 1 error, 0 warnings -------------------------------------------------------------- This error indicates, s5_pll_0002 (generated by Megawizard), Quartus tool is not able to identify. Please guide me to get rid of this error. Regards, freak4 Replies
Hi connollytr,
Thanks for your input. You were little late :) I got this file few days before and things are working... Thanks u all !! Regards, Jaseel - Altera_Forum
Do you see the qip file in the design files.?
there should be a pointer to the sub files in the mega-function directory that will include the pll_test_0002 file - Altera_Forum
This is a VERILOG code. I am using 11.2 Quartus release. Please guide. Regards, freak - Altera_Forum
what release are you using? i recommend the latest when targeting SV
that said i have successfully compiled SV designs that include PLLs
