14 years agoStratix V Low Latency Phy
Request for comments.
I am using the Low Latency PHY in Stratix V and have an odd Critical Warning: "Critcal Warning (178012): Coreclk source from 10G RX PCS ...+ long string" Pertinent parameters are Data Path Type: 10G FPGA fabric width: 64 PCS-PMA width: 64 TX_Coreclkin and RX_Coreclkin are not enabled RX bitslip is enabled The design is Qsys based. With the above, Quartus II Megawizard is happy. However, I get the above message when compiling. The compilation does run and complete in Quartus II. I do not want to convert the PCS_PMA width to 32 as I loose the RX bitslip capability. I realize the warning is recommending the use of the TX_Coreclk. Has anyone faced this problem before? I am concerned about ignoring this. Thanks in advanceNo RepliesBe the first to reply
