12 years agoStratix V GT tranceivers with unmodified output
Can the PRBS (or a LUT perhaps) be output on a GT transceiver without it going through any serialiser modification? I would like to modulate a device at up to 20GHz with a PRBS pattern. The Strat...
12 years agoAhh the old nomenclature mix up trick....Indeed I do of course want a serial stream.
Thanks Dave, Since the GT transceivers only use the PMA, all the PCS encoding is bypassed, I see that. So then does the PMA add any ecoding at all? If not, then the parallel data does come out unadulterated, and I may have a dev board for my problem. Transmitter delay will not be a problem. The modulation is for an optical link that we want to test and deserialisation will not occur, hence the reason for not wanting any encoding. Once "booted" the tx will run constantly for some arbitrary amount of time. Regards, Neil.
