17 years agoStratix III alt_lvds Timing Requirements not met in speedgrade C2
Hi there, it's me again with the Stratix III ;) I'm currently using a Stratix III with speedgrade C2 (the one mounted on the Altera Stratix III DSP Kit) and want to use the alt_lvds function ...
16 years agoHi,
Can you try to do this: Open TimeQuest Timing Analyzer in Tool Menu. In Contrainsts Menu, choose Generate SDC file from QSF Add into *.SDC file these lines: set_time_format -unit ns -decimal_places 3 create_clock -period 20 -name clk [get_ports {clk}] set_clock_groups -exclusive -group clk (clk is name of clock signal used in your design) Open Setting project and add this *.sdc file into TimeQuest Timing Analyzer Hope it works.
