14 years agostratix ii survive at high temperature 150?
Our device needs to survive in very harsh environment, the temperature might be 150 degree. Now I'm going to use military device, which support -55 to +125 degree. I would like to do timing analysis ...
14 years agoMost dies can survive 175°C with no problem, just with a worse timing. The main problem can be reliability. They will probably have a shorter life due to higher mechanical constraints on the package. But it's hard to give even an order of magnitude...
