14 years agostratix ii survive at high temperature 150?
Our device needs to survive in very harsh environment, the temperature might be 150 degree. Now I'm going to use military device, which support -55 to +125 degree. I would like to do timing analysis ...
14 years agoBefore you run timing simulations, I wonder if you should inquire if the Stratix is able to survive any reasonable amount of time at those temps with Altera. I mean you are exceeding the specified temp range by 25 degrees, I am not sure that the Stratix will even work at those temps anymore. +5C might be still be OK but +25C is exceedind the limit quite a lot.
