14 years agostratix ii survive at high temperature 150?
Our device needs to survive in very harsh environment, the temperature might be 150 degree. Now I'm going to use military device, which support -55 to +125 degree. I would like to do timing analysis ...
14 years agoHi Daixiwen,
Thanks very much for the reply. "you will probably have to constrain it at +125°C, add some extra margin in the fitter timing settings and run some tests yourself." Constrain it at +125°C, I guess you mean in setting, select operating temperature conditions at +125°C. I do not understand this "add some extra margin in the fitter timing settings", how to add extra margin in fitter timing settings?
