17 years agoStratix II GX. GXB RX/TX Channel swap. XAUI mode.
My project "10 GBit Ethernet...". I use StratixIIGX. GX Trancievers in XAUI mode.
The question is: Can I swap Rx channels? For Example GXB_RX[0]<->GXB_RX[1], GXB_RX[2]<->GXB_RX[3]. And can I swap Tx channels? For Example GXB_TX[0]<->GXB_TX[1], GXB_TX[2]<->GXB_TX[3]. If I swap chennel in Quartus GXB_RX[0]<->GXB_RX[1], I get Error: Error: Can't place GXB Receiver channel "alt2gxb:alt2gxb_component|channel_rec[0].receive" in target device because of its constraint Error: Can't place I/O rx_datain[0] in I/O location Pin_G1 because I/O is already assigned to Pin_N1 I need it to know, for better PCB layout. Thanx.1 Reply
I don't know if it helps, and if it is not too late, but check out if you can transpose the XAUI lanes in your PHY (if you use one). In the one I am using (from Texas), you can. We used this feature to simplify the routing of our PCB.
