12 years agoStratix II GX EP2SGX125 Missing
Hello everyone I can not find the Stratix II GX EP2SGX125GF1508C4 or any other variation of EP2SGX125 in the Quartus II project wizard. I also did not find any documentation about the device. ...
12 years agoThanks Alex for your reply,
I also got the impression that this device may not exist and that maybe the unit I have here were some fakes or error label, but doing a search in the internal files of the Quartus II found some curious references. Even not being available in the Quartus II GUI, the file "ddb_stratixiigx_info_j.ddb" contained in the "\ common \ devinfo \ stratixiigx \" there is a part that mentions this device: part EP2SGX125GF1508C4 # ### (User name - EP2SGX125GF1508C4) DEVICE = STRATIXIIGX5_V1 FAMILY = STRATIXIIGX NUM_OF_IO = 698 NUM_OF_LCELLS = 100464 PACKAGE = FBGA PIN_COUNT = 1508 POWER_MODEL_STATUS = FINAL SPEED_GRADE = 4 TEMPERATURE_GRADE = COMMERCIAL # ## TRAITS = NOT_LISTED TRAITS = FINAL_TIMING_MODEL DEV_RESOURCES = { "LEs" = 100464 "ALUTs" = 100464 "Pins" = 1508 "Memory bits" = 6669504 "DSP" = 60 "Embedded multiplier 9-bit elements" = 480 "PLL" = 8 "DLL" = 2 "SERDES transmitters" = 66 "SERDES receivers" = 70 "GXB transmitter channels" = 20 "GXB receiver channels" = 20 "Global clocks" = 16 "User I/Os" = 807 } end As we can imagine, it seems next to EP2SGX130 but slightly less resources. So I decided to try something. I created a new project for EP2SGX130 and before inserting any element I closed the project and changed the file "t1.qsf" which contained the line "set_global_assignment-name DEVICE EP2SGX130GF1508C4" and modified to "set_global_assignment-name DEVICE EP2SGX125GF1508C4". Surprisingly when I opened the project, no error was displayed and I could add components, assign pins and compile apparently without problems. Anyway there is still the question: if maybe this device actually exists, why it was removed from the Quartus II interface? Regards, Ricardo
