14 years agoStratix II configuration problems
Hello, I'm using Quartus-II V8.1 and would prefer to stay with that version if all possible because of legacy systems. I have a custom board that uses a Stratix II (EP2SF484C3) and a EPCS6...
14 years ago --- Quote Start --- I inadverently connected both nCS and nCSO together and are tied through a 10K resistor to 3.3V. Would that cause any problems? --- Quote End --- Perhaps. nCS should be held low. This 'selects' the first device in the JTAG chain. When that first device finishes configuration, then it asserts nCSO to the next device. The question is whether nCSO is tri-stated by the FPGA, or driven high. You'll have to look that up in the data sheet. If it is driven high, then nCS will be high at power-on, and your device cannot configure. Actually, since you have a pull-up, it will be high regardless. That would be a problem. --- Quote Start --- I checked the voltages on the 10pin header used for AS mode without the USB blaster cable. Is 2.3V correct for pins such as nCS (pin 8)? --- Quote End --- I would have expected 0V. Cheers, Dave
