17 years agoStratix II: Coil circuit
I am trying to create a very close range wireless communication using stratix II fpga. I want to achieve that using coil - coil communication. So I connected coil1 to fpga1 with a series resi...
17 years agoA coil with a capacitive load (oscilloscope probe or a FPGA input) is a resonant circuit, connecting a different load changes the resonance frequency. It's basically possible to design a wideband inductive coupling, but most likely an amplifier with suitable frequency characteristic is required.
You didn't tell about the waveform that's intended with your application.
