Stratix dev board linux network communication
I have a Stratix 10 SoC dev board and would like to use the SoC to facilitate data storage over a fiber connection to a Linux server. I assume this will require an RTOS to run on the Stratix’s SoC that could handle being the main control for the data pipeline, but also one that has the capability to set up a server as a storage device over an IP so that it can write data to the server. Is there a design example for doing this? If so, what kind of data transfer rates will it support to the storage devices?
- aikeu
Hi victor4,
I will close this thread if no further question.
Aik Eu
- aikeu
Hi victor4,
Do you have further questions based on the previous comment?
Aik Eu
- aikeu
Hi victor4,
I come across this design example found in rocketboards:
https://rocketboards.org/foswiki/Projects/Stratix10SoCDesignExampleFor10GbeWithIEEE1588PTPCapability
I not sure is it relevant to what you are trying to work on.
You can further try to find it in link below for other type of example:
https://rocketboards.org/foswiki/Main/WebSearch#q=stratix%2010%20SOC%20fiber%20connection
Aik Eu
