10 years agoStratix 3 's IO question
Hi All, I choose stratix3 for the new design recently.The target is capturing the high-speed signal which is ANSI-644 LVDS. CLK is 600Mhz, data is DDR with 1200Mbps. After reading Stratix3's ...
10 years agoYou can use the ALTLVDS to configure your SERDES mode. Since you have 8 bit/ frame, your SERDES factor would be x8. You can then set your data rate to 500M or 1G.
