10 years agoStratix 3 's IO question
Hi All, I choose stratix3 for the new design recently.The target is capturing the high-speed signal which is ANSI-644 LVDS. CLK is 600Mhz, data is DDR with 1200Mbps. After reading Stratix3's ...
10 years agoThanks for the reply. It's helpful.
I read this section and find SERDES IP i can use. Another question, my signal has two mode. Mode 1: DDR format, 8bit/frame , every frame 125Mhz, every bit 500Mhz. Mode 2: SDR format, 8bit/frame , every frame 125Mhz, every bit 1000Mhz. How can I set SERDES IP's parameters to work in SDR or DDR mode? best regards
