EShum
7 years agoStratix 10 SmartVID and Fixed PS
Hello, We have a board populated with Stratix 10 1SG210HU2F50E2VG. Device programming return errors. We found out that we have SmartVID device and a Fixed Voltage Power Supply without PMbus conecti...
sstrell
7 years agoI want to say that if you disable the PMBus pins (Device settings -> Device & Pin options -> Configuration -> Configuration Pin options; first 3 in the list), it would work. But I've never tried it.
- EShum7 years ago
PMBus pins must be enabled for bitstream generation. Otherwise Programmer returns:
Error(19192): File <filename>.sof is incomplete - Power management settings are not set up appropriately on VID part
