Stratix 10 PCI Express Avalon®-MM DMA Reference Design. Interrupt generation.
Hello !
Working with a Stratix 10 board. Per AN 829: PCI Express* Avalon®-MM
DMA Reference Design built the design and uploaded it to the board. I work with Windows. I successfully run DMA Read, DMA Write. After the end of the DMA procedure, I register an MSI interrupt.
Than want to additionally register user interrupts. To do this, I use the intx_req_i input, which became available after selecting Export Interrupt conduit interface. And also tried using the rxm_irq_i[15..0] inputs. I apply a logical unit signal of a certain duration to these inputs, but I do not register an interrupt.
As I understood from the description, I must first enable interrupts by accessing the PCIe Interrupt Enable Register, which is located at 0x0050.
Please tell me how to properly translate the address from BAR in order to access this register from under windows. The map of connections and addresses is shown in the picture. Thank you. .
