Stratix 10 Native PHY 10GBASE-R serial loopback: Rx is not always mirroring Tx
As I understand it, it has been some time since I last heard from you. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
I spent a bit of time on this issue in the last few weeks, and I can confirm that
- the clocks are definitely stable once coming out of reset
- the same issue arises with 156.25MHz or 644.53125MHz for the reference clock for CDR and ATX PLL (the clocks are provided by a programmable on board oscillator)
So I am back to where I started from: the Rx path does not always mirror the Tx path when the serial loopback is enabled, but all status signals are green.
BeB
