BeB
5 years agoStratix 10 Native PHY 10GBASE-R serial loopback: Rx is not always mirroring Tx
I am using the native PHY configured for 10GBASE-R. I enabled the serial loopback feature to troubleshoot some issues with the Tx path, and found in the process that although the serial loop...
CheepinC_altera
5 years agoHi,
Just my own experience, generally the higher refclk frequency you use, the better the jitter performance. This is because lesser multiplying factor is required internally.
