HSuh01
4 years agoStratix 10 MX Synchronization failed on bitstream download.
I am trying to download bitstream to Intel Stratix 10 MX FPGA but I am getting errors in the process.
As indicated in the image, it says "synchronization failed" error in the transcript when I try to start FPGA configuration in the programmer.
The bitstream file itself is for Stratix 10 MX and successfully downloaded before in the same version of Quartus(19.4).
I also tried example sof files that came with Stratix 10 MX, but no sof file was successfully downloaded. ( same error happens )
Power cycling FPGA device by turning on/off switch is not helpful.
Any input would be appreciated.
Thank you
1 Reply
- YuanLi_S_Intel
Hi, did u try to recompile the design in the quartus version that you are using and program it? What is the quartus version you are using?
