sroehrig
5 years agoStratix 10 GX: H-Tile Transceiver - *Direct* dynamic reconfiguration
Hi all,
I am trying to use the "Direct Reconfiguration" flow with a self-coded controller/state machine using the reconfig_* signal interface as referenced in chapter 6.7 of the "L- and H-Tile Tra...
Deshi_Intel
5 years agoHI,
Sorry I don't fully follow what you are explaining in the post here.
Let me try my best to answer your enquiry.
- Regarding design connection and how to build simple transceiver toolkit design (although you mentioned you lack of toolkit license ?)
- I have attached simple NativePHY design with toolkit enabled for your reference in previous post
- Regarding dynamic reconfig process flow example design
- https://community.intel.com/t5/FPGA-Wiki/High-Speed-Transceiver-Demo-Designs-Stratix-10-GX-Series/ta-p/735749
- Above link contains a lot of example design created by Intel FAE
- Perhaps you can download designs from 6. Transceiver Toolkit Designs and Soft PRBS Test designs (inc. Dynamic Reconfiguration) to see if you are able to port over to test on your board ?
dlim
- sroehrig5 years ago
Hi dlim,
thanks a lot for your answers. I will check all the suggestions and see how far I will get.
Regarding item 1: the downloaded file "S10_GX_devkit_ttk.qar" is only 590kB in size and when I try to open it in Quartus (I am using version 18.1.0.222) it gives me an error message:
"Failed to restore S10_GX_devkit.TTK.qar
Evaluation of Tcl script /teetools/misc/intel/qpp/18.1.0.222/quartus/common/tcl/apps/qpm/qar.tcl unsuccessful"Maybe I am trying to open it in the wrong way. Can you check the file again?
Thanks a lot in advance. Best regards,
Sebastian
