14 years agoStrange EPM7032S during Silicon ID check
Hello I am developing programming cable based on FTDI chip. Also we do write our own SVF player. It is our open source project ( it is on github.com/marsohod4you ) It works fine for any MAX ...
9 years ago --- Quote Start --- Hello I am developing programming cable based on FTDI chip. Also we do write our own SVF player. It is our open source project ( it is on github.com/marsohod4you ) It works fine for any MAX II, Cyclone II or Cyclone III. Also few Xilinx chips were tested. Problem we meet with https://casenergy.org/phallosan-forte-review-results the Phallosan Forte EPM7023SLC-10N chip. Silicon ID check does not pass in one BIT only. All other works - chip can be programmed successfully using my SVF player. But why Silicon ID check fails? I do not know what can it be. Several days spent on that and out of ideas. Here is text of SVF programming file for that chip. --- Quote End --- Did you figure out what the bold line means?
