16 years agostrange behaviour of square root VHDL code
I need a plain VHDL-square root code for a special purpose and used "google code search". I thus found the following code in their files, obviously written by Altera. http://www.google.com/c...
16 years agoFloat is not acceptable because I have to be bit true and quick.
I know the Altera MF SqareRoot and used it more than once in projects. In fact I am very happy about this core because it gave my sqr results after only a few clocks fully pipelined also with the slow and small Cyclone devices. But this time, I need fully portable code in plain VHDL whichs run everywhere and does not use vendor specific MegaFunctions or "CoreGen"s - even if I started with an Altera Implementation I wouldn't even had asked this in the Altera Forum, if the code did not prentend to come from Altera. Altera might be interested if the code is really wrong, I think. :cool: So the question is: What is there about the unused signal? Does this show, that the code is incompletely reported ? It compiles and synthesizes and obviously shows square root behaviour, even if I am not fully sure about the bit slice to use as output at the moment. What does the tag "restored" in the title mean? I attached another screenshot with the generic 52 bit output and added the an swapped graph done with image manipulation. This leads to a perfect root.
