paw_93's avatar
paw_93
4 years ago
Stop_at_clocks substitute in Quartus Standard
Hello, I would like to ask if there is a substitute of the argument Stop_at_clocks (get_fanins) that exist for Quartus Pro but doesn't work for Standard Edition? I always end up with refclock inst...
  • Ash_R_Altera's avatar
    4 years ago
    Hi Pawel,
    Got some ideas from software experts. Please try them and let me know if things work for you.
    The following procedures take a node or a pin, and return the list of all clock targets feeding it. You should be able to modify these to make them return the clock target(s) feeding the register. You can then create a map of clock targets to clock names, so that you can find the clocks that exist on those targets. Once you have the clocks, you can simply string-compare them against each other to see if they are equivalent (since clock names are unique).
    proc get_clock_targets_feeding_node { node } {
    set my_clocks [list]
    foreach_in_collection path [get_path -to [get_object_info -name [get_edge_info -src [get_node_info -clock_edges $node]]]] {
    lappend my_clocks [get_object_info -name [get_path_info -from $path]]
    return $my_clocks
    proc get_clock_targets_feeding_pin { pin } {
    foreach_in_collection path [get_path -to $pin] {
    return $my_clocks
