12 years agoSteps to constrain a design
Hello, I'm trying to understand timing constraints and I have a really hard time trying to figure out how this works. The first thing is the representation of setup and hold times. In my e...
12 years agoMy reply was about source synchronous clock path and for this case adding a multicycle of 2 to a path must be associated with hold multicycle of 1 because only then the tool can check the relevant edges. For cases such as phase shifted launch/latch clocks then the user will need to see if they have to design for an extra setup multicycle and whether to add to hold multicycle or not.
