14 years ago"std_logic_vector" is used but not declared
I worked with the book "Embedded SoPC Design..." from Chu and I have problem with my first (!) VHDL source code I typed from the book. I suppose this is very basic question - sorry about that.
The error I get: "std_logic_vector" is used but not declared ... but I thought, that is done by the use statement ....library ieee;
use ieee.std_logic_1164.all;
entity eq1 is
port(
i0, i1: in std_logic;
eq: out std_logic
end eq1;
architecture sop_arch of eq1 is
signal p0, p1: std_logic;
begin
-- sum of two product terms
eq <= p0 or p1;
-- product terms
p0 <= (not i0) and (not i1);
p1 <= i0 and i1;
end sop_arch;
entity eq2 is
port(
a, b: in std_logic_vector(1 downto 0);
aeqb: out std_logic
end eq2;
architecture struc_arch of eq2 is
signal e0, e1: std_logic;
begin
-- instantiate two 1-bit comparators
eq_bit0_unit: entity work.eq1(sop_arch)
port map(i0=>a(0), i1=>b(0), eq=>e0);
eq_bit1_unit: entity work.eq1(sop_arch)
port map(i0=>a(1), i1=>b(1), eq=>e1);
-- a and b are equal if individual bits are equal
aeqb <= e0 and e1;
end struc_arch;2 Replies
--- Quote Start --- The error I get: "std_logic_vector" is used but not declared ... but I thought, that is done by the use statement .... --- Quote End --- Your code has essentially two components in it. If you have multiple entities in a file, then you need the use statement above every entity declaration. Cheers, Dave - Altera_Forum
Thanks, that was it !
--- Quote Start --- Your code has essentially two components in it. If you have multiple entities in a file, then you need the use statement above every entity declaration. Cheers, Dave --- Quote End ---
