13 years agoState of Unused I/O pins and design of isolation filter for Cyclone IV FPGA
Hello there, Reference: Cyclone 4 EP4CE10 FPGA I m developing a prototype board with minimum peripheral say 4 slide switches, and 4 LEDs, with a 40pin GPIO, with program persistance throug...
12 years agoDear sir,
Q1. I used PDN for VCCINT power supply. PDN tool suggested 22nF(1No.) & 1uF(1No.) capacitors. Please clarify, the suggested capacitors by PDN tool are for a single VCCINT power pin or for all VCCINT power pins of FPGA. In my FPGA there are 28 VCCINT pins. Q2. I am not going to use any PLLs inside FPGA. Do I still need to use Ferrite bead between VCCINT & VCCD_PLL or if I put the suggested decoupling capacitors by PDN tool for each VCCINT & VCCD_PLL is enough. Q3. Similarly, for VCCA pins, as I am not using any PLLs inside FPGA, do I still need to use Ferrite bead between Linear regulator output & VCCA or the suggested decoupling capacitors by PDN tool is enough for each VCCA pin Please clarify. Regards, Thulasi
