14 years agoState A => State B multicycle path?
Is there a way to tell TimeQuest that all signals launched by State A and captured by State B are part of a multi-cycle path? My combinational path delay is too large so i'm adding a timer to delay m...
14 years ago --- Quote Start --- Thus, in this context, you cannot afford to have Latch_FF go metastable even for one clock. --- Quote End --- In my case it should work fine because Latch_FF.Q is guaranteed not to be used until T2. If Latch_FF goes metastable at T1 then it must mean that D will be stable for some 8ns before T2. In other words, Tsu is about 8ns with a multi-cycle path setting of 2. --- Quote Start --- Also, metastability is not ensured to last just one clock... --- Quote End --- The following documents say that a metastable condition will resolve itself in roughly tco of the FF. http://www.altera.com/literature/wp/wp-01082-quartus-ii-metastability.pdf ftp://ftp.altera.com/pub/lit_req/document/an/an042.pdf I have not been able to find tco or internal flip-flops but logic says that it must be much, much less than 8ns. --- Quote Start --- The little mistake you had is that, in this type of application, if the -setup multiplier is N, then -hold muliplier is N-1. 2 and 1 in your case. --- Quote End --- Thanks. I will update my SDC.
