12 years agoStartup problems web edition
I downloaded and installed web edition . Tried to run first tutorial and advised that the Cyclone II was not installed. Downloaded Cyclone II files and then each time I try and install -> tools -> In...
12 years ago --- Quote Start --- Do you know if there is a list of successful implementations with some idea of development time and commercial justification for FPGA selection. --- Quote End --- This question is impossible to answer without some description of the requirements. For example, if your requirements can be met using a processor, then the answer might be that you would not even use an FPGA :) The length of development time is highly dependent on the developer's experience with FPGAs (you, or your co-worker, or subcontractor), and whether the design can be implemented using standard IP, or whether you have to design and verify a lot of custom IP. If you describe what your requirements are, I'm sure you will get suggestions for possible implementations. I'd recommend starting a new thread though, since the title of this thread would not result in many people reading it (with regards to discussion of your project requirements). Cheers, Dave
