17 years ago
ssram conroller problem
i try to controll ssram... but my ssram controller works bad
my board is DE2-70, ssram model name is issi is61lps51236a
i write my verilog code....
module ssram_ctrl(input wire CLK_200, // clock
output reg [18:0] oSRAM_A, // address
output reg oSRAM_ADSC_N, // controller address status
output reg oSRAM_ADSP_N, // processor address status
output reg oSRAM_ADV_N, // burst address advance
output reg [3:0] oSRAM_BE_N, // byte write enable
output reg oSRAM_CE1_N, // chip enable
output reg oSRAM_CE2, // chip enable
output reg oSRAM_CE3_N, // chip enable
output wire oSRAM_CLK, // out -> in ssram clk
input wire [7:0] SRAM_D_A, // SRAM_D_A
input wire [7:0] SRAM_D_B, // SRAM_D_B
input wire [7:0] SRAM_D_C, // SRAM_D_C
input wire [7:0] SRAM_D_D, // SRAM_D_D
output wire [7:0] OUT_A,
output wire [7:0] OUT_B,
output wire [7:0] OUT_C,
output wire [7:0] OUT_D,
inout wire [7:0] SRAM_DQ_A, // SSRAM DATA_A
inout wire [7:0] SRAM_DQ_B, // SSRAM DATA_B
inout wire [7:0] SRAM_DQ_C, // SSRAM DATA_C
inout wire [7:0] SRAM_DQ_D, // SSRAM DATA_D
output reg oSRAM_GW_N,
output reg oSRAM_OE_N, // output enable
output reg oSRAM_WE_N); // write enable
// -- SSRAM -- //
reg SRAM_D_en;
reg [7 : 0] SRAM_DATA_A;
reg [7 : 0] SRAM_DATA_B;
reg [7 : 0] SRAM_DATA_C;
reg [7 : 0] SRAM_DATA_D;
reg [7 : 0] SRAM_DATA_O_A;
reg [7 : 0] SRAM_DATA_O_B;
reg [7 : 0] SRAM_DATA_O_C;
reg [7 : 0] SRAM_DATA_O_D;
reg [3:0] state = 4'b0000;
assign oSRAM_CLK = CLK_200;
assign SRAM_DQ_A = (SRAM_D_en) ? SRAM_DATA_A : 8'bz;
assign SRAM_DQ_B = (SRAM_D_en) ? SRAM_DATA_B : 8'bz;
assign SRAM_DQ_C = (SRAM_D_en) ? SRAM_DATA_C : 8'bz;
assign SRAM_DQ_D = (SRAM_D_en) ? SRAM_DATA_D : 8'bz;
assign OUT_A = SRAM_DATA_O_A;
assign OUT_B = SRAM_DATA_O_B;
assign OUT_C = SRAM_DATA_O_C;
assign OUT_D = SRAM_DATA_O_D;
always @(posedge CLK_200)
begin
case (state)
0 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE1_N <= 1'b0;
oSRAM_CE3_N <= 1'b0;
oSRAM_CE2 <= 1'b1;
oSRAM_ADSP_N <= 1'b0;
oSRAM_ADSC_N <= 1'bX;
oSRAM_ADV_N <= 1'bX;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b1;
oSRAM_A <= 19'b0101010110101010110;
state <= 1;
end
1 : begin
SRAM_D_en <= 1'b1;
oSRAM_CE1_N <= 1'bX;
oSRAM_CE3_N <= 1'bX;
oSRAM_CE2 <= 1'bX;
oSRAM_ADSP_N <= 1'b1;
oSRAM_ADSC_N <= 1'b1;
oSRAM_ADV_N <= 1'b1;
oSRAM_BE_N <= 4'b0000;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b0;
oSRAM_OE_N <= 1'b1;
SRAM_DATA_A <= SRAM_D_A;
state <= 2;
end
2 : begin
SRAM_D_en <= 1'b1;
oSRAM_CE1_N <= 1'b1;
oSRAM_CE2 <= 1'bX;
oSRAM_ADSP_N <= 1'bX;
oSRAM_ADV_N <= 1'b0;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b0;
oSRAM_WE_N <= 1'bX;
oSRAM_OE_N <= 1'bX;
SRAM_DATA_B <= SRAM_D_B;
state <= 3;
end
3 : begin
SRAM_D_en <= 1'b1;
oSRAM_CE2 <= 1'bX;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b0;
oSRAM_WE_N <= 1'bX;
oSRAM_OE_N <= 1'bX;
SRAM_DATA_C <= SRAM_D_C;
state <= 4;
end
4 : begin
SRAM_D_en <= 1'b1;
oSRAM_CE2 <= 1'bX;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b0;
oSRAM_WE_N <= 1'bX;
oSRAM_OE_N <= 1'bX;
SRAM_DATA_D <= SRAM_D_D;
state <= 5;
end
5 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'b1;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
state <= 6;
end
6 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'bX;
oSRAM_BE_N <= 4'b1111;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b1;
state <= 7;
end
7 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
SRAM_DATA_O_A <= SRAM_DQ_A;
state <= 8;
end
8 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
SRAM_DATA_O_B <= SRAM_DQ_B;
state <= 9;
end
9 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
SRAM_DATA_O_C <= SRAM_DQ_C;
state <= 10;
end
10 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'b1;
oSRAM_ADSC_N <= 1'b0;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
state <= 11;
end
11 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'b0;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
SRAM_DATA_O_D <= SRAM_DQ_D;
state <= 0;
end
default : begin
SRAM_D_en <= 1'bX;
oSRAM_CE2 <= 1'bX;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'bX;
oSRAM_WE_N <= 1'bX;
oSRAM_OE_N <= 1'bX;
state <= 0;
end
endcase
end
endmodule
i wanna my code's wrong point... plz help me....
1 Reply
    You should add some comments and give names to your states, it would make your code more readable.
    Then, tell us what you want to do, what results you expect, and what you get instead.
    I don't now Verilog a lot, but your assignments to bX look suspicious.
