10 years agoSPI with generated clock output constraint problem
[list=1]
[*]This interface is similar to SPI - runs with 10 MHz clock [*] I got 20 MHz reference clock in my design REF_CLK Data to transfer is shifted on falling edge on every 2nd toggle of REF_CLK clock to output port D [*] Output clock is generated by DFF {REF_CLK} [cant by generated by pll] and is transfered to output port C [*] Ts /Th of extrernal device is 8 ns [/list] in sdc i got: [list=2] [*] create_clock -name REF_CLK -period 50.000 [get_ports {REF_CLK}] [*]create_generated_clock -name C -source [get_ports {REF_CLK}] -divide_by 2 [get_ports {C}] [*] set_output_delay -clock C 8 [get_ports {D}] [*] it doesnt work ;l [/list]1 Reply
Take a look at ...
https://www.ovro.caltech.edu/~dwh/correlator/pdf/timequest_quad_spi_flash.pdf https://www.ovro.caltech.edu/~dwh/correlator/pdf/timequest_quad_spi_flash.zip chances are you can use one of the techniques in there. Cheers, Dave
