10 years agoSPI with generated clock output constraint problem
[list=1] [*]This interface is similar to SPI - runs with 10 MHz clock [*] I got 20 MHz reference clock in my design REF_CLK Data to transfer is shifted on falling edge on every 2nd toggle of...
10 years agoTake a look at ...
https://www.ovro.caltech.edu/~dwh/correlator/pdf/timequest_quad_spi_flash.pdf https://www.ovro.caltech.edu/~dwh/correlator/pdf/timequest_quad_spi_flash.zip chances are you can use one of the techniques in there. Cheers, Dave
