14 years agoSpi_slave_to_avalon_mm + qsys + pio
Hi! I try to implement very simple design using QSYS. It's SPI to GPIO converter (it's just a part of much more complicated design). I just want to control some GPIOs sending appropriate comman...
14 years ago@Cris72
Thank You for your answer. As PIO has base address 0x00 to 0x1f (32 addresses) and "data register" has offset = 0, then the address of "data register" is still 0x00? What about the whole frame that I have to send (let's say that I want to enable 4 out of 8 outputs)? Will it be? 4A 7A(Start of packet) 00 00 00 00(cmd) 00 00 00 00(addr) 00 00 00 7B(End of packet) 0F (data) CMD: 00 00 00 00 ADDR: 00 00 00 00 DATA: 00 00 00 0F (enable 4 out of 8 outputs) Regards, Krzysiek
