17 years agoSPI Interface
Hej! I just wanna know tht using Alteras SPI core...can anyone read the SD card as well. I m having some problem. I tried to use the altera Hal function int alt_avalon_spi_command(....) ...
16 years agoYes,
that´s right. You have to conect the wishbone signals with the nios signals in the top sheet. --- Quote Start --- module MICRO_SD_TOP ( //NIOSII input wire NIOS_CLK, input wire SPI_CLK, //48MHz input wire NIOS_CSn, input wire NIOS_WRn, input wire NIOS_RDn, input wire [5:0] NIOS_ADDR, input wire [3:0] NIOS_BE, input wire [31:0] NIOS_DATAout, output wire [31:0] NIOS_DATAin, input wire RESET, output wire NIOS_WAITREQn, //SD_CARD output wire SD_DATA_OUT, input wire SD_DATA_IN, output wire SD_CS, output wire SD_CLK ); wire [7:0] SD_DATA_O; wire [7:0] SD_DATA_I; wire [7:0] SD_ADDR_I; assign NIOS_DATAin[7:0] = ( ~NIOS_CSn && ~NIOS_RDn && (NIOS_BE[3:0] == 4'b0001) ) ? SD_DATA_O[7:0] : 8'hzz; assign NIOS_DATAin[15:8] = ( ~NIOS_CSn && ~NIOS_RDn && (NIOS_BE[3:0] == 4'b0010) ) ? SD_DATA_O[7:0] : 8'hzz; assign NIOS_DATAin[23:16] = ( ~NIOS_CSn && ~NIOS_RDn && (NIOS_BE[3:0] == 4'b0100) ) ? SD_DATA_O[7:0] : 8'hzz; assign NIOS_DATAin[31:24] = ( ~NIOS_CSn && ~NIOS_RDn && (NIOS_BE[3:0] == 4'b1000) ) ? SD_DATA_O[7:0] : 8'hzz; assign SD_DATA_I[7:0] = ( ~NIOS_CSn && ~NIOS_WRn && (NIOS_BE[3:0] == 4'b0001) ) ? NIOS_DATAout[7:0] : 8'hzz; assign SD_DATA_I[7:0] = ( ~NIOS_CSn && ~NIOS_WRn && (NIOS_BE[3:0] == 4'b0010) ) ? NIOS_DATAout[15:8] : 8'hzz; assign SD_DATA_I[7:0] = ( ~NIOS_CSn && ~NIOS_WRn && (NIOS_BE[3:0] == 4'b0100) ) ? NIOS_DATAout[23:16] : 8'hzz; assign SD_DATA_I[7:0] = ( ~NIOS_CSn && ~NIOS_WRn && (NIOS_BE[3:0] == 4'b1000) ) ? NIOS_DATAout[31:24] : 8'hzz; assign SD_ADDR_I[7:2] = NIOS_ADDR[5:0]; assign SD_ADDR_I[1:0] = ( ~NIOS_CSn && (NIOS_BE[3:0] == 4'b0001) ) ? 2'b00 : 2'bzz; assign SD_ADDR_I[1:0] = ( ~NIOS_CSn && (NIOS_BE[3:0] == 4'b0010) ) ? 2'b01 : 2'bzz; assign SD_ADDR_I[1:0] = ( ~NIOS_CSn && (NIOS_BE[3:0] == 4'b0100) ) ? 2'b10 : 2'bzz; assign SD_ADDR_I[1:0] = ( ~NIOS_CSn && (NIOS_BE[3:0] == 4'b1000) ) ? 2'b11 : 2'bzz; spiMaster SD_CNTRL_inst ( .clk_i(NIOS_CLK), .rst_i(RESET), .address_i(SD_ADDR_I), .data_i(SD_DATA_I), .data_o(SD_DATA_O), .strobe_i(~NIOS_WRn | ~NIOS_RDn), .we_i(~NIOS_WRn & NIOS_RDn), .ack_o(NIOS_WAITREQn), // SPI logic clock .spiSysClk(SPI_CLK), //SPI bus .spiClkOut(SD_CLK), .spiDataIn(SD_DATA_IN), .spiDataOut(SD_DATA_OUT), .spiCS_n(SD_CS) ); --- Quote End ---
