17 years agoSPI Interface
Hej! I just wanna know tht using Alteras SPI core...can anyone read the SD card as well. I m having some problem. I tried to use the altera Hal function int alt_avalon_spi_command(....) ...
16 years agoHi,
I have implemented an SPI-Core for read/write a Micro-SD card from OC. The core has to be initialized as SD/MMC controller. Then he can perform block reads/writes to the card. I´m not sure if the SPI-Controller of altera can do that.
