12 years agoSPI flash
Does anybody know if "Nios II flash programmer" support SPI flashes compatible with EPCS devices? Thanx in advance
12 years agoBy default the nios FLASH programmer doesn't recognise all serial FLASH parts.
You need to create a "nios2-flash-override.txt" file in your ../nios2eds/bin installation directory. By identifying the size and number of sectors a device has this file tells the programmer how to handle serial FLASH parts whose device ID it doesn't recognise. In your new "nios2-flash-override.txt" file paste the following:
sector_size = 65536
sector_count = 8 The FLASH programmer will now know how to handle your Spansion part. Regards, Alex
